Unconventional
Yeah I’m just gonna get the 3s and see if they work.
What did those rotors come off of?
If you can lift the car with nothing in front, that would be near ideal.So giving the idea of putting engine and transmission in from the bottom, and I have a good idea. Use a pallet jack....with modifications to work with engine...![]()
only issue would be if it gets far enough under to clear the lift cylinder of the jack when the car is lowered. @Mopar TimIf you can lift the car with nothing in front, that would be near ideal.
Clean it good and then use muriatic acid , so it etches the floor before you coat it...Hey epoxy painting a garage floor. Other than making sure its clean is there anything special to doing it??
Do it Craig. You only do it once,. It's way worth it. You got the money and the time....I'm thinking about it. I've never had a floor like that and not sure if I want one for what I'm using the garage for.
but I wouldn’t have any thread exposed.
