Would be great for that.Thanks. Agree it's light duty.
Doing floor pans in the Valiant over the winter.
Maybe I'll hold on to it. Then just give it to a member here who can use it.
I could use it......Thanks. Agree it's light duty.
Hey Wolfie....
Here is the scary part, 350 gallons of diesel fuel and probably 5 tons of fertilizer. Some of each spilled and mixed togetherLet's see, a semi frame stretched for 2 hoppers. It probably broke at the splice. You should see how the tow truck builders stretch and reinforce frames.
Would have made a nice size pot holeWorks good to make solid granite not so solid anymore.
Fertilizer hauler,would explain it.
. Very marketable skill
Called granite softener?Works good to make solid granite not so solid anymore.
in which case it was just Granite Disorganizer
Millions of tons of granite along the shorelines here.Unless we were shooting for rip rapin which case it was just Granite Disorganizer
I'm here on Phu Quoc Island now. More pics to follow.
View attachment 1715737628 View attachment 1715737629
Well, I pulled trans out today, while waiting for UPS with new parts, I examined the trans close. There was a leak run of fluid from the front seal. So I changed the seal, and once UPS delivered (2pm) I put in the new B&M holeshot converter and B&M external balanced SFI flexplate, installed trans and took for a 10 mile drive. No Leaks!! Pic of the leak...
Starting to sound like me.Got the cars moved around yesterday. Pop is out, R/T is on the lift and the cuda in the other bay, What a PIA doing it alone! Nothing is running but the truck and it has NO BRAKES!
