dukeboy440
Oh here ya goThanks. I would hate for you to waste all those keystrokes. There's plenty of action in the N&P.
Comes with it's own integrated transport system?I'll sell the harness to you. 15 grand....
A couple nice cars. That's the problem looking for a car like I want. I don't need a Max Wedge or a clone. (note that $55,000 price tag)
whenever I paint stuff, I like the 2x rustoleum.Got these painted. This paint covered good, but not at all impressed with the spray. Krylon has much better, consistent spray. Was just a slight breeze, should not have been an issue. Just didn’t get a nice wet coat. Kinda like when I sprayed Cinnamon with the HF gun.
Hmm sounds like that Vert might be what you need thenA couple nice cars. That's the problem looking for a car like I want. I don't need a Max Wedge or a clone. (note that $55,000 price tag)
Now the Belvedere is a bit spendy as well for a roller but unless you do all the work yourself, $25,000 is a reasonable price to pay for what you get. I don't even want anything bigger than a 383. (don't need all the power, bad mileage, and it drives the price up.) I would look at a slant 6 car but a 273, 318, 361 or a 383 would be great. I would love to find a 273 and dress it like a Charger 273. Poly's are cool with a 4 barrel and some cool aluminum valve covers. (spendy I know) Nothing wrong with a 361 or 383.
For what it’s worth. I found the tire selection better and more cost effective on 18s vs 17s. Plus 18s clear enough to let you run 275s and 285s up front. That’s an 11.5and 12.0 wide tire for comparisonHowdy all. Tomorrows the day for Claudia. We have to be at the hospital for 6 am. Wanted to throw a big thanks out to @MOPARMITCH for the help on my master cylinder problem on the 71 Swinger. Also found a collapsed rear brake hose on my own. While I had the rear tire off I mocked up the adapter and 17" rim that it may sport if I ever get to autocross the car. Ignore the center cap.View attachment 1715817783 View attachment 1715817784 View attachment 1715817785
18 seems to be todays standard. 16-20 are available on new cars, so most mfgs will at least have ‘normal car ratios’ Selection becomes limited more with each size as you go bigger or smaller. 14’s are getting really tough to find…For what it’s worth. I found the tire selection better and more cost effective on 18s vs 17s. Plus 18s clear enough to let you run 275s and 285s up front. That’s an 11.5and 12.0 wide tire for comparison
Yep. Try find hay wagon tires these days. None existent18 seems to be todays standard. 16-20 are available on new cars, so most mfgs will at least have ‘normal car ratios’ Selection becomes limited more with each size as you go bigger or smaller. 14’s are getting really tough to find…
Actually you cant get much cheaper. For White or black, the 15oz can of 2x is 5bucks at Home Depot! I don’t know what you call a light coat, but to me a coat of paint is a complete wetting of the surface. The 2x coverage allows good coverage with a misted tack coat and one full coat.to me this is what I buy when I want a cheap ‘glue job’. Lol. Krylon is thinner and atomizes very well for a nice light coat.whenever I paint stuff, I like the 2x rustoleum.
Expensive but it really does look good when its all done.
But I usually go with 5 or 6 super light coats and one thick coat on top. It takes forever, but it works great.
krylon is a little to watery for me.
No I can prove it also! Instigator!Few nice days hear before chance of rain and getting colder Friday. Near 70 today. Gonna let the inside painting go for a bit. I need to clean up the baseboard heater covers and spray paint them outside today. Clean up the garage AGAIN. Maybe wash a car or 2...
Hey @halifaxhops - they said last night was a 'waxing' moon. Did you get your legs done?
I found that ceramic paint works great on baseboard covers
12 to 15.What do you guys think that 64 would be worth in PA. Running driving. New top. No rust. AZ all its life...
A bet is a gamble.I am going to check it out. Bringing 5 gallons of gas, electric fuel pump, new battery, fresh oil, if i can get it to start, and goes in gear, I will buy it....15 grand used to be a lot of money, but it is not any longer...I bet it could get 15.....
On the way....
When was the last time you saw a b body convertible rust free for 8 grand or less
Good luck.On the way....
If you buy it, for that, today!When was the last time you saw a b body convertible rust free for 8 grand or less
