Back from a visit to the vampires.....
Did you have an appointment for a blood test with Dr. Acula????
I want to keep my 94/360 in the 3/4 ton. It has maybe 60,000 on the factory replacement engine.I told you those 5.9L engines are rockets....
I have my dad's 98 Grand Cherokee Limited 5.9L with quadra-track and it moves non-running cars around my back yard barely off idle... Torque monster....
It's quick and torquey, but drinks gas like a drunken sailor....
Man, its almost been a week with no forum for me.
In the meantime, the duster had a charging issue and I found out both the VR and the Alternator (both alternators I had) were bad. This caused each test drive to end in pushing the car home.
I thought I fixed the issue by putting a jumper on the alternator but apparently not. I found out that it did not work on the way to the winter formal dance at my school.
It died in an intersection, and I had my mom bring my truck to take me the rest of the way. (about a 1/4 mile)
I think its trying to kill me.
The amount of times its just shut off in intersections is alarming. That was 6 I believe.
You need to duplicate the problem without being in an intersection.
Foot on brake, vacuum booster, transmission load and brake lamps illuminated. Low voltage and it quits. Get a voltmeter to put under dash.
Could I see the same change at the ammeter?
I know it was constantly discharging when it was running, and it really went down FAST whenever I turned the headlights on.
YesIs that where you set up your shotgun deal???
its not the only thing wrong with the wiring.
just all the little gremlins that it has.
nothing too extreme, just problems that fix themselves with no sign of anything wrong. Every once in a while the key will just do nothing. Its been fine for a few months, but when it happens it is just a ***** to deal with.
also the rear running lights just stop working now and then, but when I look for shorts, or bad grounds, everything is fine.
ok, if I get a buddy, could we just put the voltmeter on the battery? or the output stud on the alternator to see if it is charging?
New Swap, Not Charging
Damn, he want's a fortune. Pass.Saw some ladder bars for sale, I bit and took a peek. Big Boy selling them, hard pass. Should have looked closer.
Meh I want a set of drag master traction devicesSaw some ladder bars for sale, I bit and took a peek. Big Boy selling them, hard pass. Should have looked closer.
I know where there are some Bars for Lads.......Saw some ladder bars for sale, I bit and took a peek. Big Boy selling them, hard pass. Should have looked closer.
Good evening men....
I am definitely trying to soak up as much info from everyone as possible, I'll get my voltmeter out when I put the new parts on to make sure it's fixed.
Ammeters are so passé. Ignore it and get a voltmeter.
Wish i made a video at this point in time. Alternator troubleshooting and wiring. Lets see what is bouncing around fabo…brb!
fail! So lets see what you have first of all. Install your new alt/reg and leave battery disconnected for the time being. I want pics of regulator mounted and connected. Same with alternator. And proof of battery grounds to firewall engine and battery.
If you do not have a volt meter,you should.
Ok, I will PM you tomorrow when I have time to mess with the car. Thank you
They are arresting people for theft!!! Are they kidding???Grab some for me, I'm on my way....
The internal alarm clock woke me at precisely the right time to view the spectacle at it's highlight. No luck. Heavy overcast.
