Stop in for a cup of coffee
Today I'm hoping I don't get too many C list flakes, just posted a for sale on our old TV, it was a 2012. Got an OLED on black Friday.
I need to look up parts and see what they fit, or start a new thread on what is this part :lol:
And as always I will give my friends a heads here in the coffee thread a heads up on what I will sell here first..lol
I just went out and cut the lawn for the winter. I told my tenant it was too high, and needed to be cut. It's his responsibility, but he's dragging his feet. They are from Texas and dont understand yard work...So I waited until they left today for kids sports, and I cut it myself....
Find someone to watch gunner yet?
What kind? I had an old 25in 'big' TV listed for a long time. Was practically giving it away. I had a converter box with it for antenna. Said could have the TV if they bought the box. Ended up dropping it at the electronics recycling center...
Was a Sharp Aquos 70" LCD. Had an issue with one "line" burned out, thin but could be seen with light backgrounds, watched it like that for 4 years. Bought a 77" LG.
That does sound like it was a nice $$$ TV. Not sure if that problem is in the screen or board. Might find someone that will fix it or use the parts. Problem is the parts changed so quickly between models
It happened after it was moved, was picked up gently but a heavy set.
77? How big is your room? I've got a 55. The way the room is set up we are watching from 8 to 12 ft away. Any bigger I think would be too much. Originally sized the center cabinet for a 25. Later expanded it for a 51 projection. That had wide borders, so I was able to put the 55 flat screen in its place. Probably could have gone to 58 max now since the new ones have almost no frame edge, but stuck with 55 when I just got a new one.
Walked down back this morning and saw a couple areas that have a little more leaves than I want to let sit. Think I will go do a final run with the mower then blow all the crap out of it and from around the spindles on the deck. Then it's done for the season and I can pull the starter.
This Pin Cherry came up on its own about 15ft from the big tree I had removed. It was leaning too much from being shaded. I figured the other tree caused it to lean, it can help me straighten it.
One hearty derelict brought his Model A Roadster :D actually it's not bad out there if you stay in the sun. Again no Mopars in the gathering :wtf:. Tried new coffee dispensing establishment that opened recently. It was built in the parking lot of a long since moved GM dealership which has undergone major renovation in the last year or so. Locally owned place, it moves up the list above Starblecks on first try :D.
They were bikinis there haha?
