Can't like that. But glad your getting something accomplished - even if its learning the hard way.
My memory from using the usual fel-pro set is to get the cork end gaskets hooked into the little fingers.
Just a bead in each corners where the cork doesn't go.
The standard gaskets have rings seals around each port. Hold them in place with plastic buttons that help line them up.
The most difficult part is getting all of the bolts started and going around working them down. Try to do the tightening following the sequence in the shop manual. It should help get them snugged up evenly. Dual planes are a PIA. Sometimes just have to use a box wrench 1/4 turn at a time. Have fun. LOL. Never mind. Just make a zen thing. Left foot right foot and eventually you get there.
