Yesterday, I gave away two 14in small bolt steel wheels to my HVAC Buddy.....
Joe's Tire and Alignment is your friend. String and a tape measure isn't accurate enough when machines measure in 1/10 of a degree.Well, apparently I wasn't able to recreate the initial alignment as well as I would have liked. Vibration.... not anything violent but doesn't feel right. Guess I'll need to play with it a bit. Caster and camber are a challenge. Toe is good
Yep. It’s fine to get around during a build or while you have burner tires on. But even the PO S Neon got shop alignment when I bought new tires.Joe's Tire and Alignment is your friend. String and a tape measure isn't accurate enough when machines measure in 1/10 of a degree.
You ain’t far off. For two packs of hot dogs, a gallon a milk, a loaf of bread, two pounds of potatoes salad, two packs of buns. And a watermelon, equaled 101.35… this morningWhat ya get? Milk, bread, eggs, pound of hamburger and a 6 pack?
That’s nuts! I actually got 2 for $5 on Ballpark beef dogs last week. I’m sure I could do under $30 for that order.You ain’t far off. For two packs of hot dogs, a gallon a milk, a loaf of bread, two pounds of potatoes salad, two packs of buns. And a watermelon, equaled 101.35… this morning
Yeh, prepared stuff like that is ridiculous. I gave the wife hell for buying already cut up melon last week. Was like $5 for a little container for honeydew and cantaloupe. The whole melons are like half that and it takes a couple minutes to cut one upWTF Where do you shop? The 2# of potato salad is the problem. I could get all that for $25 or so.
Kroger. Each pound was 8.99. Milk was 3.99, hotdogs were 2/5 Ecrich. They were out of the cheap buns, so I got stuck with the 6 dollar a pack ones.WTF Where do you shop? The 2# of potato salad is the problem. I could get all that for $25 or so.
Watermelon was 7.99…Yeh, prepared stuff like that is ridiculous. I gave the wife hell for buying already cut up melon last week. Was like $5 for a little container for honeydew and cantaloupe. The whole melons are like half that and it takes a couple minutes to cut one up
Exactly.prepared stuff like that is ridiculous.
Uhh. OK.
But toe is done last.Toe is good
Ride ht, - > camber - > caster - > toe.
recheck camber after caster as those two are tighty related.
Alignment shouldn't cause a vibration. It should cause pull or tire wear, which eventually might cause cupping.
Strings are OK for toe.
Need a bubble gage or digital version for camber and caster... I assume you have that.
I gd I remember doing that!Been working caster camber with a plumb bob and measuring tape. I'll go back through in that order and see .
Buy local and in season.Watermelon was 7.99…
Talk about the toughest way to do it.
Do you have any smooth, somewhat level and flat area? I have a "hitman alignment" system in the box. Havent used it in years. its a PIA as the dust covers need to be removed from the hubs - and also two wheel nuts.
It is in season.Buy local and in season.
OTH if that was a 25 pound watermelon, maybe not a bad price at all.
Blue berries and strawberries going for about $5 a quart at the farm market. Def higher than past years. Peaches just coming into season $2.50/pound. Cheaper if you go the farmstands of course.
Couple of coffee club tips.Is there any rules of thumb when it comes to adjusting the caster bolts on the UCA?
