There is a double jointed spark plug socket for that pesky #3 plug…havent used mine in eons..Just put 6 spark plugs in a 02 Blazer V6 4.3. What a PIA.......
Welding shop. There has to be someone around with a tig welder. Its the “in” thing now, being able to weld aluminnium.I called every place up here and the last guy I talked to said the last person who did it up here died. then said good luck and hung up.
No worries, I got it done, by turning the steering column to a flat spot. Used a universal 5/8 plug socket...BUT...Not so easy....There is a double jointed spark plug socket for that pesky #3 plug…havent used mine in eons..
even if it's the tubes Inside the radiator leaking? won't they have to take the entire thing apart?Welding shop. There has to be someone around with a tig welder. Its the “in” thing now, being able to weld aluminnium
Tubes inside? You lost me. If its leaking, perhaps you can get warranty? An inner row of tubes leaking with no external damage, i’d try it.even if it's the tubes Inside the radiator leaking? won't they have to take the entire thing apart?
its leaking from the center of the radiator; not the tank. Its just spraying from in between the fins.Tubes inside? You lost me. If its leaking, perhaps you can get warranty?
They just need to remove the tanks and solder the leaking tube closed on both ends..its leaking from the center of the radiator; not the tank. Its just spraying from in between the fins.
Or. TIGThey just need to remove the tanks and solder the leaking tube closed on both ends..
Mom is home. Feeling much better. I'm relieved.....
Definitely good to get outdoor stuff done early.
My brother's work has been sending staff home early. 18th century mill...so there's no real climate control going on.
I have a Holley Avenger 670 cfm waiting in a box, this 650 Eddy is my start up carb to get everything spinning, water and trans fluid is next in line, just need hose clamps
RRR can prob help you out with that he is into the slants. @RustyRatRod
Oh my, and yet you can still make me laugh
Hey Tim
How's the ribs doing?
Wow, white with white interior. Don't see that often.
I found out on the late local news last night that the SpaceX Falcon launch today was scheduled for yesterday. The launch commander scrubbed it at T-46 seconds no reason was given for the abort order..
That mug just plain looks guilty as sin with zero regrets. Clearly he will do it again until you are trained.
I toss in a couple of things that I can always use. Added one more set of jets and 2 cans of degreaser this time
Good for them, I just spent an extra $32 to save $12
Some peckerhead has been calling repeatedly,wont leave message. Im not answering as i prefer not to deal with him. He can’t be trusted. Besides, i have been sawing and hauling trees. But i cant lift my legs anymore. Tripping on nothing. And its hot.
Saw works better than i expected.
OK cool...
I've come to sorta expect being an oddity because it all sits on top of a 225 slanty... I've read a lot of the threads on here concerning carburation on these (particularly 4bbl /6 setups). There's usually a fairly vigorous discussion that occurs with opposing factions. I have some folks that I lean toward their opinions primarily. .
