Forgot to post this picture of my dual sinks, only cold water supply, never said I was an artist or plumber
See if you can get the drain pipe lower than the transfer pipe between the 2 sinks (the 18" pipe)
Yup, i use .023, it's great for trying to get thin metal/rust to stick togetherGood Morning everyone. Got another patch panel in the Charger. Floor/firewall section. Man I need the rollers for smaller wire for my welder. What a PIA when using too big of wire on not just sheet metal, but old crappy metal.
My rollers have two groves dont yours?Good Morning everyone. Got another patch panel in the Charger. Floor/firewall section. Man I need the rollers for smaller wire for my welder. What a PIA when using too big of wire on not just sheet metal, but old crappy metal.
Yes 0.030 and 0.035 I believe. I need the smaller onesMy rollers have two groves dont yours?
Let that beuityful sun shine in, out in the shop plumbing my sinks in, well, the wife's sinks ..A little clean up to do but this will work well. Hey, I can see my computer screen!
Had to useJust talked to the warranty guy at edelbrock and sent pics.. will see what he says.. Of course there is no stock of the intake.. I wish i knew if a RPM air-gap would fit under my hood..
Not a fan of those. One backfire and melted foam goes down the carb and into the engine. I have seen it happen a few times.
