I still need to decide if i'm gonna try using my 1962 pump that sat for 45 years.. or my LA pump with unknown miles..... Gotta roll them dice The carters look rebuildable but read up that they really aren't (the old school screw together ones)
Used to be able to buy kits. Not any more.I still need to decide if i'm gonna try using my 1962 pump that sat for 45 years.. or my LA pump with unknown miles..... Gotta roll them dice The carters look rebuildable but read up that they really aren't (the old school screw together ones)
yeah.. i honestly trust that 60 year old pump more than buying a new one... i'm sure the diaphragm has to be shot thoughUsed to be able to buy kits. Not any more.
OutstandingYes...
Should be today
That La pump could be a good one, my vote is the LA with unknown mileageI still need to decide if i'm gonna try using my 1962 pump that sat for 45 years.. or my LA pump with unknown miles..... Gotta roll them dice The carters look rebuildable but read up that they really aren't (the old school screw together ones)
And will carry a spare in the toolbox in the trunk.. along with a points dist and spare coil... i have never been towed home and don't wanna start nowOutstanding
Same here, and a ballast resistor. I got towed in one time, just up my driveway after my 66 Sedan was struck by lightning, replaced the ignition wiring when it was my daily driver, great little 170 /6 I put togetherAnd will carry a spare in the toolbox in the trunk.. along with a points dist and spare coil... i have never been towed home and don't wanna start now
*adding a jump wire to my list of spares to carry... Never had a ballast go bad but it will happen eventuallySame here, and a ballast resistor. I got towed in one time, just up my driveway after my 66 Sedan was struck by lightning, replaced the ignition wiring when it was my daily driver, great little 170 /6 I put together
Waiting on 7 thirty, auto parts store opens, need new fuel line, oil filter and air shock air line kit .Man some of you guys are up late posting.
Had to do a little back reading to see if I missed something exciting
That's the risk.yeah.. i honestly trust that 60 year old pump more than buying a new one... i'm sure the diaphragm has to be shot though
Not sure what I am going to do today. I cruised around on my trails yesterday with the ATV. I need to walk them and clear them of broken branches and sticks.
Got a new video with none other than @RustyRatRod
In the aftermarketWatch out for the spring force. Its too high on some of the Carters. Should max out around 6 psi, not 7 or over.
And be prepared to deal with high pressure. Check the pressure to make sure. Mopar Joe a buddy of mine replaced the pump on his 383 with a Car Quest replacement. The damn thing always ran rich, black smoke, loading up etc. Joe is one of those guys that doesn't diagnose the problem just goes another direction. He had a 500 horse 440 built. When we swapped the engine, I transferred the pump to the new engine. It ran pig rich as well. He had a stock car buddy come over one night to tune the AFB but couldn't lean it out far enough to make it run right. I got thinking that the pump was transferred to the new engine. We checked the pressure and sure enough it was 7+ pounds. AFB's only like 5# tops. He went to Car Quest and bought another pump, put it on and it was 11# right out of the box. A regulator fixed the issue. So be aware. Sorry for the long story!That's the risk.
Changes in fuel composition in the early 70s killed some rubber parts. And that happened again a few times after that as Im sure you know.
There are some guys who rebuild fuel pumps, have parts, and/or will uncrimp and recrimp the crimped types.
Mancini had rebuild kits for the after market carters. Not sure if they still do. Watch out for the spring force. Its too high on some of the Carters. Should max out around 6 psi, not 7 or over.
It lasted a long timeView attachment 1716111193Morning . My pump after 20 years.
