Stop in for a cup of coffee
Well... went into the guest bathroom to put away a couple of towels... stepped between the commode and the tub... felt the floor give... :mad:
Nothing on the surface so water must've been seeping from the wax ring under the linoleum.
Christmas project defined. Crap
Glad I found it at least. I don't go in there often. No indication on the downstairs ceiling. Feels like minim of new subfloor and then linoleum or tile. Probably pull everything except the tub
sounds like a crappy job.
Dang... stumbled across a picture of my Jeep... didn't realize there were any
A few hours of Christmas set up here today. We took a break with the snow coming in to clear a few gutters of leaves and pull the cushions and put the covers on the patio furniture. Watched the Ohio State- Michigan game while we worked. Took the rest of the afternoon off for the Iron Bowl another good game. Our favorite teams both play this evening and now with two TV's we can watch both. Enjoy the football!!
Hope y'all had a great Thanksgiving. I just returned from the Az desert and T-Day with the brats. Was there any real important back reading i need to do since last Tuesday? The granbrats had a hockey tourney so hockey was the subject of the visit. What a hoot to watch that was :lol:
Tons, you gotta do it
Arghh, can’t like that.
Anyone have a picture of an Early A, V- 8 pedal bracket and linkage attached to interior firewall?
This does not even remotely appear to be correct or fit... but it IS what is pictured in the Parts manual.
Contours seem all wrong in the sheet metal and no bolt hole alignment.
I traced the bracket shape on the firewall with a cardboard cutout of the interior bracket...
Photos from the sides and top to show the variance in the firewall from the plate.
Why do you want to change it if car wasn’t built that way? Is your drawing specifically for Canada?
Swapping the /6 for the V8 ... plan was to put the proper accelerator pedal in. But then I figured out that that pedal that is in here now is a mid-70s setup... so anyone's guess at this point. All I have to go off of is the parts book, body book and assembly manual.
Or go all hot rod and build your own? Wilwood has a great modular kit? It even comes with a three pedal option!
I may be able to use what is in here already... I could probably just find a 73 Plymouth V8 cable.
Regardless, I hit my limit of "**** that doesn't go together right" fur the day. Gonna join ya with a little brown water and look through some books a bit
