Stop in for a cup of coffee
Pirate ship?
Happy Saturday. Regular work day, sort of. Making up some hours I missed, so not OT :(. At least it's only one press running, so should be relatively easy. Maybe catch up on a few things...
Looks like 22F is the highest we might get here today. Starts a gradual warm up after that to 50's and rain later in the week. Should clear most of the snow away. I'd say there is 6+ on the yard now between the 2 snows we just had. Still need to clean up the driveway from last night. I need to get more firewood in. Although, after the next couple days, it will probably only be burning at night. I don't get good enough draft above mid 40's, and the heat pump is pretty efficient at that point anyway.
I agree, my 350 is due for cap/rotor plugs and maybe wires, can you imagine what that would run on that engine
I wonder what the spacing between the sparks is or do they both gire at the same time?
Fire at the same time. Did one of those distributors a long time ago The Acel one though. Just a hotter spread spark. They both run off a crank trigger the only reason they are there is to pass the spark to eACH CYLENDER, NO POINTS OR CON IN THEM AND THEY ARE USUALLY LOCKED OUT.
Morning all. cold start here but getting to the low 40s. Need to start sorting some parts to sell at the TRI state swap meet in 2 weeks.
