I have four right now. Great price if it all works.You better buy that
Morning Chris what's happening today? Nothing going on here.Fred of the North
Good day Sir
Past the point of diminishing returns? Like with any engine, there is a limit.man.. watching how much this guy put into this 318 then dynoing it.... makes me sad... i wish someone had warned me bout them.. i need to find a 360
You have a full day for sure.Need to get down into the garage and get the engine out of the truck, swap it onto the stand and get all the externals bolted up today. Need to figure out some space and shuffle things around a bit. I think I'm done with the snowblower for the season, so I may work on a way to store that out of the way. Also have the old 225 sitting here... hate to set it outside until I figure out if it is broke-broke or something simple.
Not getting ANY of that done, sitting here at the kitchen table though.
Good ideaGot a wild hair last night having a drink and looking at my scamp thinking what next.
Never liked a rear spoiler on cars that much but think I might carve one out of foamboard just for fun and see if I can design one that fits my car.
naw.... he did 270rwhp which isn't bad.. i just love the 318 hatred is all.. thinking of switching to the 360 side so i can look down at 318 people alsoPast the point of diminishing returns? Like with any engine, there is a limit.
Or maybe a bad idea. lolGood idea
Naw... i'm ok with my 318 If i find a 360 for like $100 for the block i would consider it.. was mainly joking around. Luckily i'm not a guy that has to worry bout sizeLike this?
This is a very hard to find 1970 (First year) 360 Dodge engine with the flat top pistons, not dished like later 360's. Casting date is 9-15-70, built for a 1971 vehicle. It has a fresh set of 1975 360 heads that have hard exhaust seats, new valve job, guides cut for teflon seals, pocket ported and ports are gasket matched, 1.88 intake and 1.60 valves. Intake is an aluminum Edelbrock Performer, new water pump, has a truck oil pan, 340 valve springs with damper, Crank is drilled for a 4 speed, holds 60 pounds oil pressure. Pick up in Cumberland, Md. 21502. Carb, distributor and exhaust manifolds don't go with it, They're for our run stand.
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
True and if it doesn't work out it was still worth the experience.Most of the innovations of the world began as a really bad idea......
Where is Karl when we need him?Luckily i'm not a guy that has to worry bout size
Guess it would help if I posted the picSo question. Factory 360 valve cover, as seen here with my age 14 dumbassery fix, the top cover leaks around this cap thing. Any ideas on how to fix?
Looks like you need another cover. One with oil fill.
