Stop in for a cup of coffee
Apparently today is international women's day in Vietnam. Guess I'll have to buy some flowers or a gift somewhere. But I've also been informed that there is a party at my house at 3:00 p.m. today. Not sure how many people will be there but I'm sure it will go for 5 or 6 hours. :lol:
@Icetech
Looks like it may be this....................70's casting, TE for truck engine part
The D2TE-AA (as with most FE heads since the start of 1966) have smaller intake runners (increases fuel/air velocity to improve emissions), lowered exhaust runners (apparently a unibody change - can be a problem with tube header alignment), smaller combustion chambers (more valve shrouding apparently improves fuel atomization), thermactor emissions bosses (often undrilled), and unibody exhaust manifold bosses (generally undrilled).
The D2 heads are 70's casting and have induction hardened seats for unleaded gas. Other than that both castings for the most part are identical. Just watch the exhaust bolt patterns as some are drilled for 8,14 and 16 bolt holes depending on the application and exhaust manifolds. Neither are a performance head but std FE heads used on cars and trucks over the years. The most common of upgrades is to install CJ size valves. A little port work and some chamber polishing will help also. Casting numbers will denote the decade,year,application (car or truck) and production changes. Ex C8AE-6090-H, C = 60's, 8 = 68, A = Ford part, E =engine part. 6090 = production part number for heads, H = 8 levels of changes made to design. Also parts will have a date code. The D2TE-AA heads are 72 heads hence the D2. The TE is truck engine part. 6090 the head part number and AA the level of changes.
Some welding done. Fitted heater box, so i can mock up the defroster duct. Goes where im pointing to. Straight up from the heater box. Need to build a flapper and use the S10 vacuum pot to open it. Or not.
I am having fun watching you on You Tube. I must say, it seems that retrofitting something that has been designed for some other vehicle takes a different skill set than just starting from scratch. I'm glad it's you doing it. Like I mentioned, I am like a bad doctor, no patients. :lol:
He has a YouTube?
These are so good. Just the right size and wrapped in bacon. What could be better. Oh, they sell them a few days a month at a local convenience store. 4 for $5. What could be better? I'll post some after photos later.
@Icetech
We put D0VE heads on my son's 460. 1970 casting small closed chamber larger valve.
See if you know we're this ones from.
Pretty Betty has her car ready
I know a girl named Ann and one named Sue
But they can't fix a car like Betty can do.
Now Joanne's cute and Mary's Sweet
But Betty has them all beat.
Her car is quick and roars like a Tiger and the guys are Jealous cause her cars finer.
You have me stumped on that one
It's officially Spring here today :lol: High of 57° and sustained @ 20 mph with gusts to 30 mph :lol:
I would take that, have to wait till 15th to see that temp! Frank you make me feel SO lazy, amazing how much work you get done in 1 DAY. TMM I'm down with that steak, no brainer!
It's one of the local seasons, daily 20+ mph winds, March thru May temperature varies. I noticed looking at the NWS weather map long ago that this area is almost the same latitude as the old desert homeland. Spring out there is much the same with a little more velocity and lots more flying real estate :lol: .
You don't get June Gloom as far North as you are do you? Encountered that when I was stationed on 32nd St. San Dog
1/2 days actually. By noon or 2:00 my legs and hip wont let me continue.
If it wasnt for this project id be laying on the couch all depressed.
