Morning......................
X2Morning......................
Will these coils work on late 80s M bodies with the stock ignition?OK white print 87 and up at least, ecu/dist marked so at leats 72 up since it says ecu. Print is low also. Still a 28K coil. Well worht the buy it price.
Actually I think the tower connector is different. The older ones use a "male" coil wire end the 79 up uses a female style kind of like a Hei term inside the tower itself. . I have the later ones nos if needed about the same price.Prob what engine\.ign?
318 with the stock "electronic fuel control system" computerProb what engine\.ign?
That's OK. It looks the same as the coil that's in there and I got curious once you said it was a good price. I don't want to cook the computer though because it also acts in place of the ballast resistor. Magic 80s voodoo! I'm not putting serious money into it. That engine won't be in there next year. Just waiting to find a 360 at the right price.Dam my mopar does not go that high. Not well versed on 80's stuff. Thats a 24 part numbes so around 65=65 ish fitment.
Washout here also.Good morning everyone. Nothing to report but more rain.
I see a lot of them down in Pennsylvania, Ohio, and Maryland. Ain't much out this way. I've looked at a couple and haven't been thrilled by eitherLots of them on Marketplace lately.
What exactly you want?I see a lot of them down in Pennsylvania, Ohio, and Maryland. Ain't much out this way. I've looked at a couple and haven't been thrilled by either
An LA 360 that isn't a complete mess. Whole Magnums go for around 600 in the yards here, and the LAs that I've seen people want more than that for a whole engine. Might as well magnum swap it once all the costs are taken into consideration.What exactly you want?
At least we beat them in snow totals around here...Here's a fun weather fact, so far this year Los Angeles has had more rain than Seattle, that is VERY unusual
The was a 2000 R/T 5.9 and trans that came up a few days ago. I will post it if I run across it again 60K on itAn LA 360 that isn't a complete mess. Whole Magnums go for around 600 in the yards here, and the LAs that I've seen people want more than that for a whole engine. Might as well magnum swap it once all the costs are taken into consideration.
