Stop in for a cup of coffee
3 champ fights including Fury Vs. Usyk (i pray usyk wrecks him) 5 belts on the line in that fight alone...
Plus a really awesome undercard..
Prelims are on right now and good fights in it even
Used to watch the fights with my Dad, think it was Friday Night Fights. Watched all of the classic heavyweight fights and remember some of the light/middle weight ones as well.
yeah, i hadn't watched in about 25 years then a couple of years ago i started again and some of the events are just great. Some are not... If you ever wanna watch lemme know and i'll give ya a site. cause $70 to watch tv.. **** that
Just sayin'
A piece of tubing with the end sharpened. In a drill. Works slick! As a bonus, push a pick in from the bottom and its bang on every time.
I use the gasket punches.
Sounds good Frank , the only reason I use heat is to cauterize the hole so it does not fray.
Left dart in rain with the drivers door not closed. Of course rain ruined drivers kick panel. Made a new one this morning. I made the original one as well...
Ran out of things to do today and not a TV watcher during the day or much of a couch potato.
Waiting for parts for the grandkid's minibike so that's on hold.
I just took the wife to meet her exercise girlfriends. Big bus load of them going to Vung Tao today to enjoy the ocean and the beach there. That's about a 3 and 1/2 hour trip each way .She won't be home until around this time tonight here.
And Mitch home alone, what could possibly go wrong. :poke:
Steering column in... went under the car doing stuff and after all the grinding/corroseal and paint i have surface rust coming through on the floor again.. just insane.. this car is cursed.
Afternoon everyone, normal day in the get to do it twice shop. Had to change out the cam in the turn signal switch with one of those Doorman things. Got it changed out, put back in, now I have nothing in the rear of the car. Turn signals and flashers work in the front but not in the rear, I do have running lights in the read but no brake lights. Got one on order should be here Tuesday. And just for grins I hit my washer bottle and broke it. Need to soak my head in a bucket of water.
Well on the bright side of things you found it, but yea been inside out of the weather so only thing I can figure is moisture was trapped before you sprayed it.
Not sure if my washer bottle is the same but I have a spare if you need it. Ho! And a towel when your done soaking your head. :thumbsup:
no idea... i'm in the house now.. not in the mood to work on it. Need to relax..
