Stop in for a cup of coffee
So have to cut exhaust to remove trans. Three places. Then I hope I left enough room on trans tunnel when I modified it for gear vendor. That is a big question.
Lost me on the tunnel and Gear Vendor fit?
Had to heavily modify trans tunnel to install gear vendor overdrive. Top rear is tight. Might not leave room to pull trans back enough to remove it.
Little G&T on the front porch. Still 87° , but a breeze and humidity isn't bad.
Had to roll over to JBAB in DC today. Man there are some jackslaps on the roads.
Why is it that Navy facilities are always "not nice" (and I'm being generous)
I like the "smaahht" thermostat in the house. Kept it high while I was away, then 45 minutes from home, turned it down a bit so it was comfortable.
Obviously I do not know your shop layout, but no way you can lift body off and remove from bottom? Maybe some creative rigging? Alternatively rent some kind of equipment to lift it off if you do not have any way to rig? You are a smart guy so I am guessing you got it sorted out but that just sounds like a sucky deal all way around?
I am prepping for hockey now!
These are great for Summer sippin
I went out and flew the drone around a little bit. First flight. I did pretty good. I took off from the roof of the kids car and landed back close to the same spot. I was setting in a chair in the driveway and flew it up close and then followed it around the yard and up the street. It's a lot easier to fly it away from you then back to you. Just a little practice. I was good until the mosquitoes started swarming. It's hard to be steady on the controls when you are swatting skeeters.
That is how I installed everything. So there is that option...
