What's up Rainy?Evening fellers
There are no coolant lines that connect to the Cummins intercooler, it’s an air to air cooler.Antifreeze can appear in a Cummins engine's intercooler if there is a leak in the engine cooling system, specifically where the coolant lines run close to or connect with the intercooler, allowing coolant (which contains antifreeze) to mix with the compressed air flowing through the intercooler.
You make a nice couple but I'm thinking your wife is prettier than you.
Hope you're doing well.Evening fellers
O heck yes!
Thru intake valve into intercoolerEven if that were true, on a Cummins head, there’s no way for it to enter the intercooler
But who knows...Thru intake valve into intercooler
No question! She is a keeper for sure!You make a nice couple but I'm thinking your wife is prettier than you.
howdy RainyEvening fellers
Intake is dry as bone. As normal.But who knows...
I’m so dang puzzled by this thing.But who knows...
Espresso Grind in a vacuum packIs that ground or beans?
Air gets into the cylinders, so coolant could find its way back. Unless turbo has coolant running through it. Then from turbo?But how does that get into the intercooler? I’m just trying to wrap my mind around it
John will tell you she's lucky to have one like me.No question! She is a keeper for sure!
Sorry, trying to get back to sleep.Good morning, Mike. I'm still Lovin on those 66 Darts.
me too if it's possible.Good Morning All! (and I might do the same Mike)
