Here we go another thing going away Cam lube for points!
Dang, I bet I threw away a handful of those little capsules throughout the years. What kind of grease is it and can you use something else close?Here we go another thing going away Cam lube for points!
We use so much of it, it's a threat to the environmentHere we go another thing going away Cam lube for points!
We use so much of it, it's a threat to the environment View attachment 1716332336
NASA must have something similar that the EPA is not allowed to screw with Just contact your customers at The CapeI use it alot. I save all the little packs and pills for the customers. Prob use a tube a month. Only have one left. Prob silicone grease might work.
I GOT IT! Bacon Grease! Since it's an animal by-product it's compostable and environment friendly. Plus, every time the Distributor cap is removed, it will smell like breakfast.Here we go another thing going away Cam lube for points!
But, but, but it melts at 140°-160°. That will make a mess inside the cap. It sure will smell good though.I GOT IT! Bacon Grease! Since it's an animal by-product it's compostable and environment friendly. Plus, every time the Distributor cap is removed, it will smell like breakfast.
Give the epa time they will find something wrong with that too and ban it too much red tape bull s—-I GOT IT! Bacon Grease! Since it's an animal by-product it's compostable and environment friendly. Plus, every time the Distributor cap is removed, it will smell like breakfast.
Did they print up without much hassle ? Looks good
I remember that down in YumaThose EPA peeps need to live downwind of a large piece of ground they use for broccoli farming. About the third day after harvest and they hit the remnants with the flail mower to ready it for composting and discing it back into the ground they will be on a new quest. "OMG! The wind must be blowing from the City Sewage Disposal Plant"
not sketchy enough for another lift day.
Yup went to portrait. Thats just on paper, Going to UPS tomorrow.Did they print up without much hassle ? Looks good
Looks good, maybe some color to make it stand out.Yup went to portrait. Thats just on paper, Going to UPS tomorrow.
Those pads are to keep the advance points cam lubed evenly you should use cam lube also. They use cam lube basically to keep the parts that runs on the hex lubricated so it does not wear down, Thats all.I used to use Blue Streak points so I never put any lube on them. I wonder what they used on those little red pads? Never had a set close up.
60 is bad enough, just throw in a slipped disc and sciatica. Some days i wonder if i will make it to 70..I know where you are coming from. Off to the Dr. today. I have a list of things to ask about. She always asks about depression. Of course I'm depressed. I'll be 70 in June and I can't5 imagine what the next 10 years will be like. That would bum anybody out.
Sketch-o-matic?
I'm 66. 3 Herniated discs over the years in back, surgery for sciatica, stomach hernia with a mesh but keeps getting bigger. Arthritis and bone on bone knees. Still kicking but it sucks. I feel your pain.60 is bad enough, just throw in a slipped disc and sciatica. Some days i wonder if i will make it to 70..
I have a bulged L3 and 4 disc. It acts up occasionally and is now. I should have it seriously looked at. It sure isn't doing me any favors.60 is bad enough, just throw in a slipped disc and sciatica. Some days i wonder if i will make it to 70..
