Stop in for a cup of coffee
Here is something I need an answer on. At first we started the old truck with a 8 volt battery but it died after a lot of use. so we jump started the 6 volt system with a 12 volt. Now even fully charged the 8 volt won't turn the engine over fast enough to catch. An old tractor owner said we have fed the 6 volt starter with 12 volt cocain and now need to get the starter rebuilt? Thoughts?
6 volt starters have heavier windings than 12 volt. They tend to turn faster, but thats about it. I had a good conversation with a rebuilder many years ago, said polarity and voltage wont hurt a starter. I ran 12 volts to many a 6 volt starter, my cockshutt is a perfect example, cantankerous to start, especially in cold weather. 15 ish years running on 12.
I found some seat belts for the 64. I don't know if I should just get the ones to clip on the existing rings or get some that bolt to the floor like regular belts.
Another sampling box coming today. We haven't tasted through the last one they sent 3 months ago. :BangHead: :BangHead: I am going to drop that program.
The VWs we raced liked the 6v starters on 12v, but they didn't live long.
Windlace is going better, i had to redo parts of it, and using upholstery nails is way better than staples. More work,but more accurate placement. Think i need to shop around for an upholstery hammer.
My windlace is faded. I was thinking about trying some black shoe polish. Just a thought.
Tool truck folks
Usefulness of this?
Seems like one of those things that you rarely use but you need it when you need it. 50% off
Multispline Screw Extractor Set, 25-Piece
I can't speak for the Harbor Freight quality, but in general, those are a very nice set. The larger sizes will extract pipe fittings and they are short enough they won't usually bottom out before they get tight.
The ICON line gets some good reviews from what I have seen
High to low
Icon
Quinn
Pittsburgh
