Hey still on for the 16th I have to drop her off around 2 or so with the tsa wait now I think, Her flight is 5 or so I believe.
I do. I always take my polar bear dip in the winter.Dam Ray you can swim with the fishies in that!
Yes I am ring me up.Hey still on for the 16th I have to drop her off around 2 or so with the tsa wait now I think, Her flight is 5 or so I believe.
Put in an amended claim. You can do that you know.
which is precisely the way they want it to be.It is confusing since the itemized list is kind of vauge that they sent me.
Yep. Kinda generic..1 # Pre-wash, clean 1 1.0
Note: Press wash hood, fender, engine bay..Soot removal
2 ** Repl A/M Wiring harness, engine 10127 1 574.99 8.0
Note: Painless Performance Products LLC
2501 Ludelle Street - Fort Worth, Texas 76105 Phone (817) 244-6212
3 # R&I Carbuerator 0.7
4 # Repl Carbuerator, overhaul kit EDL-1477 1 49.95 2.0
Note: Summit Racing Equipment - 1-800-230-3030
5 # Repl Intake gasket kit MRG-5994MRG 1 139.95 1.5
Note: Summit Racing Equipment - 1-800-230-3030 - Incl. intake manifold and valve cover gskts
6 # Repl Plug wire kit w/dist cap SUM-867807CR 1 56.94 1.0
7 # Repl Air cleaner assy EDL-1002 1 20.99
8 # Repl Brake booster, m/c assy RSD-G80011001 1 235.31 1.8
9 # Repl Radiator hose kit 1 21.99 0.6
10 # Repl Battery B30% 27-3 1 116.99 0.2
Note: Advanced Auto Parts
11 # Anti-Freeze (Per Gallon) 2 24.00
12 # Material & Supplies 1 20.00
Actually that is fairly detailed. Lookes like each price is followed by labor hours. i.e. 574.99 for a painless harness and 8 hours to install. they only gave you a rebuild kit for the carb though. 2 hours to rebuild it and .7hrs to remove and install....2 ** Repl A/M Wiring harness, engine 10127 1 574.99 8.0
No, they are all on now.Keith still need those lower fender clips and studs? I have a good pair from the belve, I am starting to box what is left and they are in there.
You're not wrong...Your always foggy!
they would put that in the rebuild hours, only if it had to be done.. will only give you shop time for the min a shop would do to get it going. Now if you show that it is not rebuildable and had to be replaced... that's good for the amended claim. Be sure if you need little stuff, sensors etc that they give you the labor time. Probably more $ than the part!.7 is a joke takes me a few hours with cleaning it. I usually take all the lead plugs out and blow out the passages then put them in and jb weld over them to take care of any leaks.
