ScampMike
Despicable Damn Yankee
I thought you did plugs, rotor, cap and wires when you first got it - - no?Might put new plugs in the Fury today. I can do that and it will be a good feeling.
because you just aren't cool enough to be a 43...
thats my concern.it's probably not to scale... I would expect your fender flares will need to be a lot higher on the fenders in reality
yeah... noand that hood is oh so very cowl looking...
Not necessarily. Where they are placed will be dictated by vehicle height, suspension travel and wheel dimensions. Typically fender flares are put on after the full suspension and wheels are in place and final ride height is set. Until then, the wheel openings cut outs get modified as you go with the front fenders last since you can leave them off until everything else is set up.it's probably not to scale... I would expect your fender flares will need to be a lot higher on the fenders in reality
George!hey hey!
Just the electronic ignition kit. I was kinda surprised the shop didn't give it new wires then but that's something easy to do myself. Also surprised they wouldn't have re-gapped the old plugs but then new plugs are cheap and easy for me to do myself.I thought you did plugs, rotor, cap and wires when you first got it - - no?
Heya timGeorge!
heey heeeey heeeeeeeey....hey hey!
and it gives you a half a chance to get your hands dirty tooJust the electronic ignition kit. I was kinda surprised the shop didn't give it new wires then but that's something easy to do myself. Also surprised they wouldn't have re-gapped the old plugs but then new plugs are cheap and easy for me to do myself.
I'll probably stick with them. but I'm not sure i'm gonna need them to be honest. Unless I wanna run a 28 in tire on the frontNot necessarily. Where they are placed will be dictated by vehicle height, suspension travel and wheel dimensions. Typically fender flares are put on after the full suspension and wheels are in place and final ride height is set. Until then, the wheel openings cut outs get modified as you go with the front fenders last since you can leave them off until everything else is set up.
Wasss SsuuuuuuuuuuuuPPP?heey heeeey heeeeeeeey....
hard dicks and helicopters?Wasss SsuuuuuuuuuuuuPPP?
no idea... Google!Any here know if the MSD 6AL and MSD 6A wire the same, use the same connector, direct swap?
All MSD 6 series use the same PN 8860 wiring harness.Any here know if the MSD 6AL and MSD 6A wire the same, use the same connector, direct swap?
My d*ck if you rub it!!!! lolhard dicks and helicopters?
you know - - *ahem* working...Wasss SsuuuuuuuuuuuuPPP?
you boys need a room??My d*ck if you rub it!!!! lol
lolyou boys need a room??
hey, I'm getting compensated for being here - it qualifies...
