Stop in for a cup of coffee
He
Not watching the game myself but picked up a can of cheese sauce and some rotel from Walmart, heated up together to dip with corn chips. Crumbled up some leftover sausage pattie into it too.
I bought some marine 2-stroke oil, the kind that has t3c or whatever it is. A engineer guy on another forum did a study and came up with adding 1 oz per 5 gal of fuel in your tank, to make your car run better and counteract the effect of the ethanol. He says you get a little better mileage too. No harm in trying. The Fury does seem to like it.
As long as it doesn't start smoking like a Lawn Boy.
I use to do this with my diesel truck. It did truly work. And probably way I got over 300k out of my factory injection pump when most are lucky to last 100k
That is one of the best snacks to eat. I've never added sausage to it, but I like it with out.. I could eat the whole thing in 1 sitting.
That is interesting, keep us posted on how it turns out for you.
don't get things mixed up or you have oily chips and Fury exhaust will be pumping out cheese farts :lol:
Yep, it's kinda like running Marvel Mystery oil. I use Aces IV fuel additive for the same reason. It's a great top cylinder lube, I've been using it in my SRT for the past 70k miles.
The small amount you add, they say doesn't cause any smoke or odor....we'll see.
Yep Ramie, I am going to have to stop myself soon lol.
I always used Marvel my whole life, love it, but this is cheaper and maybe better? I will let you guys know if gas mileage improves noticeably.
The old mechanical pumps need lubrication. I put a quart of atf in my fuel tank every once in a while. Keeps things working good.
It should be fine. You just need check the plugs regularly and make sure you aren't fouling them.
