Stop in for a cup of coffee
I am seeing newer car wheels on 5 on 4 1/2 bolt pattern A bodies, what are they and is the metric bolt pattern on these (Mustangs or what ever) fit correctly ? Everyone jump in with your thoughts please
Seriously considering playing hookie today from work
That's a good question Mike. Gotta go see ya.
Most Mustangs run a 5X4.5 (114.3mm) bolt pattern, so their wheels will be a direct fit on our lbp a bodies.. width, offset and diameter may not work, but the bolt circle is the same..
Now to find out what wheels I seen on a Dart not long ago, looked like a fox body mustange wheel, thank you Ben.
Thank you for being a RockAuto customer! To show our appreciation, we have a special discount for you.
Your discount code is:
5722691951044707
How to Use Your Discount Code
Enter the code above in the "How Did You Hear About Us?" space on the checkout page (above your payment information). Do not enter any other text in that space or the discount will not apply.
Please note: Discount only valid for orders placed online. Code must be entered before order is submitted.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.
This discount code expires on April 9, 2017 so don't wait!
Thanks again for buying your auto parts at RockAuto!
www.RockAuto.com
5 on 114.3mm, The brake hub dust ca
Oh wow !! Thank you Ray :thumbsup:
Now, what wheels am I seeing on members cars that are not stock Mopar wheels or after market, seems I am seeing some mustang wheels on out A bodies I will use this info to find out Rat Thank you sir :thankyou::thankyou:
There are a couple thread on using mustang or bullet wheels. Not exactly a bolt on. The offsets and backspacing are different for different wheels and require some very careful measuring and spacers. The Mopar hub is larger and requires maching , and then there is the problem of having a hard time getting the center cap on the front. I'll see if I can dig up some links
Yes failing 1 of her classes as in 36% grade... I mean really failing. and a D in another one.. She is easily a B student, but she just doesnt care and would rather socialize... I guess I have higher standards than her mom
Have you tried restricting the cell phone... That tends to be a distraction that they don't need...
The more I think about this it is just wrong kind of like
