ScampMike
Despicable Damn Yankee
yea - we did this before - are you at your FIL again?So anyone ever heard of this reality show called Naked and Afraid?
Yes first time in almost 2 months lolyea - we did this before - are you at your FIL again?
Time for an intervention..Yes first time in almost 2 months lol
He's obsessed with this show. It's sad, he has the box set now
Thinking soTime for an intervention..
Yes! She could be my ex-wife...I have to ask this though. Do you think it's truly possible for a man and a woman naked, alone in the woods, sleeping in the same shelter to not have sex?
yesI have to ask this though. Do you think it's truly possible for a man and a woman naked, alone in the woods, sleeping in the same shelter to not have sex?
Maybe. Does the guy look like you?I have to ask this though. Do you think it's truly possible for a man and a woman naked, alone in the woods, sleeping in the same shelter to not have sex?
Might consider a haircut tho!
Mystery solved.
Mystery solved.
Wonder how they got all that grease out that can
Gear lube. It is pumped out using a pump cover that goes over the can. Once it's empty they pour out any residual and wash out the can with soap and water.Wonder how they got all that grease out that can
Mystery solved.
Hmm I have two of those, both about half full of heavy duty shell brand water proof and high temp grease. Been thinking about combining the two into one and cleaning the other out for the shop can but shop and degreaser don't work on this stuffGear lube. It is pumped out using a pump cover that goes over the can. Once it's empty they pour out any residual and wash out the can with soap and water.
Grease is harder to clean out. First remove as much as possible manually (shop towels, etc.) Then use hot water or steam to liquefy and float the grease to the top of a water layer, let it cool and scoop it off. Then use liquid Tide laundry detergent in large amounts with very hot water to scrub the rest out.Hmm I have two of those, both about half full of heavy duty shell brand water proof and high temp grease. Been thinking about combining the two into one and cleaning the other out for the shop can but shop and degreaser don't work on this stuff
Purple Zep, mineral spirits,Grease is harder to clean out. First remove as much as possible manually (shop towels, etc.) Then use hot water or steam to liquefy and float the grease to the top of a water layer, let it cool and scoop it off. Then use liquid Tide laundry detergent in large amounts with very hot water to scrub the rest out.
Believe it or not, they use the equivalent of liquid Tide and steam to extract the last bits of crude from spent oil wells.
Tried those on this stuff before, niether worked just turned it colorsPurple Zep, mineral spirits,
