Stop in for a cup of coffee
Anyone have tips on removing front and rear glass on this Duster? Other than "carefully"
This info from dukeboy sounds like he knows :thumbsup: I still say an E string from a guitar will work also :usflag:
yes, 4 people minimum. Piano wire, a very strong fixed blade, very sharp, QUALITY knife to cut the sealant, make sure all trim is removed first. A heat gun also works to help soften the sealant. Best tip, if you want to store the glass, do not do it flat as it will break. Go to Home Depot/Lowes, get a couple sheets of 4x8, 1/2 inch foam HD board and sandwich the glass between them and tape securely for storage.
yeah, that said, dont be surprised if the glass cracks or breaks, it is 40+ years old after all. I'm shooting less than 50% on pull windshields, backglass a little bit better, but its the curvature of the front that can cause issues. My best luck has been with 4 people, 1 on the inside holding, one outside cutting, 2 on the outside ready to catch and go.
I am debating if my 66 Sedan needs frame connectors , as we all know the sedan's are stronger and I will not be putting it on the track with slicks and hammering it hard, I am running 2.45 gear sure grip.. What yall think
I've done a couple of windshields on the old flat glass VW beetles, but that was along time ago and they were much cheaper and easier to get! would rather not screw the pooch on this!
Always yes to subframe connectors.
Good luck. Nice part, Glass for Mopar A bodies is still made believe it or not. 250 bucks is what I was quoted locally for it, installed
Thanks , I was thinking this would be a good time to get that dun, she does deserve all she can get from me right now, thanks
Question. Have you talked recently to the owner of that other car you gave the title and keys too a while back?
:wtf::BangHead:If I needed 4 people to do anything on my car it never would have got done.
Are you re-using them? If not it's a one person job. To save the glass, best to have 2 people. If I had 4, I'd be telling someone to go get me a beer so they would be out of my way. LOL.
Wipers off. Trim off. Just pull the round cord out of the gasket. cut the web of the lip that goes over the glass and pull it off. Gently push the glass from an inside corner to get it started. This is where it is good to have a second person outside so you don't launch it when it lets loose. (If not saving, blanket on hood and pop it forward) Unless someone gooped it heavy and recently with sealant, you probably won't need to wire it. Set on edge on foam or a couple layers of cardboard for storage. Cardboard between is sufficient. The front is laminated and is pretty tough. back is the touchy one. It is safety glass. Even a slight tap on an edge can shatter it in a million little pieces. Could run some tape around the edge if you need to store it.
She's had it for several months now, but doesn't know where it came from!!!
Lookin good. She does stop in the coffee shop occasionally.
Different than Nella's, looking forward to see how this one goes together.
I would like to re-use the glass, but I am a firm believer in "**** happens" so if i can't, then i can't.....
So you're saying youre the size of 4 men?!
what cord?! I've yet to pull one that had a cord.... mine were all glued in with some sort of sealant/glue all 5 of the mopar from that area I've owned and pulled?!!?! Does this mean at some point all of them had glass replaced and simply done half-assed by whatever shops did them?
there is virtually no way you'll be reusing the gasket - so don't worry about ruining it - it's about getting the glass out in one piece. It's not stupid heavy, but when you have it balanced over the front of your car - it is more than one person should be trying to do
Nice that you have a lift, after placement would be much easier to finish the welding on the rack. No fun welding on your back!
I agree, and that is a friends lift , and he is the installer just up the road a couple miles away, Victoria has been high and dry at his shop all year.. good guy that knows what he is doing .
No I have not, I did see the car on the street in a parade 5 or 6 years ago.
Pretty sure my gaskets were original/factory and had round cord. My Precision brand replacement was identical. Yes there is likely sealant on it, but likely just butyl or silicone crap that does not adhere well. Not like a glued down glass where you need to cut through it.
hmmmm good to know, ive had to cut mine each time, there was still a gasket around the top surface of the glass hmmmm
