What? You have something screwed up.Well fooling around with the tune, I really idles nice with 35 degree initial advance and 1200 RPM. So if I do that, I need to put in the purple stop bushing. I think....
Vacuum leak is my first thought.What? You have something screwed up.
yea, you know, I'm just sitting here going with the flow and not really thinking about it too much - my engine and Tim's are quite similar, mine idles at around 8-900 and IIRC is set to somewhere around 12-15 initial.. things that make you hummVacuum leak is my first thought.
In the end analysis, Im really trying to mask the too tight converter with a tune.yea, you know, I'm just sitting here going with the flow and not really thinking about it too much - my engine and Tim's are quite similar, mine idles at around 8-900 and IIRC is set to somewhere around 12-15 initial.. things that make you humm
damn man - you must have one heck of a stack of those things by now..My large garage signs were delivered today. These are really nice quality...
oh and I get it - a TC swap while a basic thing on it's own, is a PITA because you've got take out either the engine or the trans..In the end analysis, Im really trying to mask the too tight converter with a tune.
Yep....oh and I get it - a TC swap while a basic thing on it's own, is a PITA because you've got take out either the engine or the trans..
not looking forward to it huh? so which way for you - engine out or trans out?Yep....
Trans out im thinking....not looking forward to it huh? so which way for you - engine out or trans out?
OSB should be cheaper by a few bucks. Nothing wrong with OSB if it's thick enough for the application. Is this something you will walk on? I think minimum thickness on 16 centers is 5/8 for floors regardless if Ply or OSB. Might even be more by code now. Not to say you need to do that for a storage area in the rafters. I don't have any floor in mine. It's open from the garage going in above the house area. I just walk on the trusses if I have to get in there. (wiring, etc) Haven't stuck my foot through the sheetrock .. yet.yea - I'm thinking price is going to be the deciding factor
there are already boards up there, no issue walking around - it's a loft in every sense of the word, now I just want to clean it up and be able to more readily use the space - - you know, so I can play with my hard wood in my loft..OSB should be cheaper by a few bucks. Nothing wrong with OSB if it's thick enough for the application. Is this something you will walk on? I think minimum thickness on 16 centers is 5/8 for floors regardless if Ply or OSB. Might even be more by code now. Not to say you need to do that for a storage area in the rafters. I don't have any floor in mine. It's open from the garage going in above the house area. I just walk on the trusses if I have to get in there. (wiring, etc) Haven't stuck my foot through the sheetrock .. yet.
Uh-oh...severe thunderstorm warning for next hour, 60 mph winds, large hail and lots of lightning strikes.
Be safeUh-oh...severe thunderstorm warning for next hour, 60 mph winds, large hail and lots of lightning strikes.
give her 6 inches and she's good to go..
dah - 'tis just a minor gusty with some wet-n-pelletsUh-oh...severe thunderstorm warning for next hour, 60 mph winds, large hail and lots of lightning strikes.
Quite the load of crap you got there. lol
fixed itI've had bigger crabs after a long weekend....
I think he was going to miss all that crap he tossed. Went out and fell asleep in the dumpster.
well, the phone call ive been expecting for 4 days has just been received. my grandmother passed about 45 minutes ago now
When I was in the Navy, I had a 64 Sport Fury, convertible. 426 Auto. Sold it like a dumb *** after I got married. Had it almost 20 years.
That seems to happen to most of us... get married, the toys go away
I did find some great pieces of hard wood though - too dark to be sure what they are, - way too heavy.
