dukeboy440
right now, stock cam, the only thing I see myself doing anywhere in the near future is a switch from a 2 barrel intake to either the dual 4 barrel or a single 4 barrel for the poly
Morning ToolmanMorning guys
Those are coolI am sure I have something for it, the reason I asked I have a few accel dual points which have the means to set three different mechanical curves in them.
just a runner. Not really in a rush, gonna at least be 2 weeks before I even get the car homeHow fast do you want one? I am sure I have something on the shelf, all the LA fit into it, looking for year correct or just a runner?
yeah, id need the entire thing.I will put something together for you. Need the cap and rotor also? Just so I know what to send to you. Just pay the ride. You hooked me up with the tester for sure.
i actually said the same thing this morning.ahh - work.. nice and relaxing
and you sure?I will put something together for you. Need the cap and rotor also? Just so I know what to send to you. Just pay the ride. You hooked me up with the tester for sure.
Upholstery adhesive!still trying to decide what to do about the roof/walls of the loft area of the garage - - need something to trap the dust... is there something I can spray on there?
humm.... the stuff that you use to put up a headliner?Upholstery adhesive!
here's my suggestion. we used this in the one barn/mini shop we resided and re-roofed 2 years go. keeps dust way down and it helped insulate it. No joke, it's usually 10-15 degrees cooler in side/ and 10-15 degrees warmer in the winter then outside.still trying to decide what to do about the roof/walls of the loft area of the garage - - need something to trap the dust... is there something I can spray on there?
nice - staple it up?here's my suggestion. we used this in the one barn/mini shop we resided and re-roofed 2 years go. keeps dust way down and it helped insulate it. No joke, it's usually 10-15 degrees cooler in side/ and 10-15 degrees warmer in the winter then outside.
Cool Shield Thermal Bubble Roll - 48" x 125', 3/16" S-9911 - Uline
Not really sure what you are trying to do... If you clean it, blow it out, it should not continue to 'make' dust. Even if you cover it, the new surface will eventually be covered it dust. Now if you box it in, it may have less surface area and coating could be smoother- that could keep it from retaining as much dust and make future cleanup easier.the underside of the roof is rough side of the tongue and groove boards - hell, I'd paint it if I thought the paint would stick..
