ScampMike
Despicable Damn Yankee
no, no I'm not... go figure huh?!Are you building a ferry boat????
and hopefully it stays that way!Lake Mike is dry!
I should have checked them for buffing pads. I bought Chemical Guys pads through Amazon. Wanted the Quantum pad, but the orange pad came up on backorder so I got their regular hex pad instead. Held up fine and did the job. Only issue was the center of pad buckles in when it gets hot. That problem is supposed to be solved by the hole in center of the Quantum.
this Allensfasteners site seems to have a lot of neat stuff...Looked at them the assortment and price sucks, need a bunch of different lengths.
fuel tank filler neck gasket -DMTAnyone know what the name of this gasket is? It's for the fuel tank filler neck. Can't seem to find it. All I can find is the grommet.
DMT MOPAR 71-76 A Body Fuel Filler Tube Gasket Duster | eBayfuel tank filler neck gasket -DMT
Doc Day for me, checking to make sure I don't own a space ship somewhere or have one in me
You sure can dig some dandies up
Oh I am , fine, my wife said I was this morningGood luck... Hopefully everything's ok...
Casting Numbers | Hot Rod ReferenceThanks it is a start!
Thanks, distributor casting numbers do not seam to matter a 318 and a 440 can have the same one, same cases, just different stamps/tags. just looking for MP dist numbers, really do not trust looking them up usually all I can find is on e bay.
