No Idea. Ever look at Max's truck on the vac lines?
Good morning gang.. is it really foggy in here or is it just me?
well, I was feeling overwhelmed to find I need a different bell housing due to wrong bearing retainer size AND I found I need a new crossmember for the 4 speed.
I am a bit relieved now to find that I can modify and use my original cross member
I made a statement yesterday that I don't like to modify parts .....well....I guess I take that back in light of what I discovered with the cross member. Basically the auto and 4 speed cross members are the same EXCEPT the auto has a box section welded to the front of it and the center isn't cut out from the factory. SOOOO to make a 4 speed unit I need to cut of the extra welded on box section and cut out the center and BAM ...4 speed cross member.
I came to this conclusion by reading a thread on Dodge charger dot com and plus I notice that brewers sells a four speed unit but they specify that it was made from an original automatic one. They want a nasty core charge and it works out to close to 200 bucks and I see originals get anywhere from 2 to 2.5 bills.
so today I guess I will get the grinder out and the mini-sawzall and see if I can save myself 200 bucks.
Take his panties off your head and it will look normal.
Thanks Hoppy. Worked like charm. All clear now..
Two lines around three feet long, one has a white plastric receptical? thingy on it.from the transfer case shifter area, not to the axel, those are there. Enjoy the Eggs!
Where are they coming from?
So it was not foggy after all it was HAINZEY!
On top of the transfer case lever somewhere, I cant get a look at it. The manual has nothing on it or the lights on the dash to show what you are in in the "message" area. I am thinking one is vac and the other? Just a big jigsaw puzzle so far but I found the comers!
How is the weather there today Rick? Oh by the way happy Birthday! LOL
