Stop in for a cup of coffee
Circulation over the top of the firebox and under the cast iron housing.
at least temporarily.. just use another fan to blow air over the stove. I have a small pedestal fan in the basement that we use to get the air moving more. Otherwise we have 100 degrees within 10ft and cold farther away
That looks lonely in there!
Mike the induction motors still have windings around the rotor in the stator part, have a feeling it is opening in the heat, easy bench check with a load light.
I just want it right dam motor assy was 130!
It is a ebay thing sent them a message. Pay pal should cover it if they wont replace it, I have dealt with them before decent store in Jonestown, PA. They are the only place that has parts for this thing that I have found.
I might have to go to the burg and get some rivets, I am actually out of them and the asswipe hardware store here does not have them.
You should just check the ohms, might need a ballast resistor, check the website I do not know the part #'s off hand.
Ok
I don't know if it will work with electronic ignition. It will work with points
currently it's electronic. The car was converted years ago. I plan to go back to points.
Yep, That's right.
Hey who is going to try to get to Carlisle this year? I know the PA guys will make it any one else?
Some of our group will be there. That's right, you already met Mopar Joe. I want to go this year and may be not go to the Nats.
He was a good guy that mopar spring kit work for him? I gave him one hell of a deal think it was $10
I actually have a few of the Mr. Gasket spring sets, that's a rare one to find now. I have been looking for a Mallory set but they are far and few between to use in mine.
