Stop in for a cup of coffee
I had a 70 sport fury before and main reason I traded it off is because it was just massive and I couldn't see in front of the hood or even out of the 1/4 Windows very good.
I traded it for my green 69 dart ..... much better fit
1970 sport fury is a C body.
Hey I got 8" of sSNOW! Crap really do not want to deal with this today!
I think we only got about 3".
Think I will just hit the drive, should melt fast this week, already falling off the roof.
Supposed to be around 70F tues and Wed plus more rain this week
Dist lots, or lots of dist???
yes
See the flathead stuff, the 12 totes are probably worth more than most of that stuff. Got enough smalls in my garage already.
I could use some totes. Wonder if he has the lids. LOL
I can't drink.
He meant free water. Just be careful if its yellow and served in a cup.:D
Good Morning
Those seats
Yup I have A, B, C and E body
I have a 66 polara now and the way the dash is , makes it better visibility than the 70.
In 70 the dash sits up higher
have adjustable brackets for short people, sold a set and that's how I met Barry
Bearings with poly crank
bearing with la crank
forgive the duplicate picture.
With telescoping gauge the rod end bores are virtually identical
Plasti-gauge on one bearing so far .0015,good bearing on good crank with rod from good block.
Just so you are aware, LA rods and poly rods do not interchange without heavy modifications
LA Rods and Poly rods? I don't know for sure about them but we have Poly wogs and them little suckers can change! Right into a darned frog!
That's it, I'm over these damn drum brakes, four wheel disc conversion coming up.
Damn! You must be made of money.. Must be nice to be able to buy parts on a whim.
Not at all. I just happen to have kept the front disc set up from my dart when I went with the Gerst set up. They are able to be swapped onto the 64 B bodies! The rear will come from the budget kit... aka a rear set from a Grand Cherokee in a junkyard.
Heavy modifications? Rod casting numbers are the same. Rod ends are thicker, as in no side play. I cant get a .002 feeler in. Should be .010. #1&2 so far. 3$4 have. So im going to swap rods.
ball joint press and 1/2 hour on the lathe. Goes pretty easy.
Heavy modifications? Rod casting numbers are the same. Rod ends are thicker, as in no side play. I cant get a .002 feeler in. Should be .010. #1&2 so far. 3$4 have. So im going to swap rods.View attachment 1715143492 ball joint press and 1/2 hour on the lathe. Goes pretty easy.
Just going off what is published on Allpar about the poly and what parts interchange. It's entirely possible that with the machining to get that poly crank into the LA block that they machines it to use LA rods.
Went to have brunch with the grandaughter today. When i arrived there was a suprise waiting.
My daughter flew in from Alaska.
