Stop in for a cup of coffee
Or in goathumper land
Skeet shooting using a rifle and golf balls instead of clay pigeons.
Just gotta change the rules to yell “Fore!” instead of “Pull!”
I dont do moving targets very well.
Scatter guns take a little practice.
I was target shooting 565 yds.so hitting the target while its stationary is easy. Never was any good at moving targets.
I ran a little ready mix plant that was just a couple blocks from the local country club/golf course. I was forever finding golf balls in the parking lot area. None of my guys played golf. Probably 400 yds to the fence of the country club. I doubt they had had any hitters big enough to reach me. Not like I didn't give them reason. I had a contractor that was installing concrete golf cart paths there. The contractor didn't believe in concrete pumps, so where the path went, so did the mixer truck. My mixer driver calls me "Alex, got a problem over here at the golf course". Unloading parallel to the path on the grass on a little side slope, found a very wet spot in the grass, mixer sidestepped down the hill and wound up with a 12" diameter tree trunk neatly between the cab and mixer drum. I load up another 6x6 mixer with water and send it over with tow cables. It worked fine until the tree hit the mixer drum and brought both trucks to a spinning halt. Groundskeepers chose to cut down the tree over tearing up more of the grass.
