Stop in for a cup of coffee
He lowered it with the torsion bars.
I’ve also noticed that the passenger front wheel sits out a few more inches from the fender then the drivers side does. Looking down the side of the car...you can tell there’s a difference. Would you or anyone know the reasoning on that?
Would have to make sure wheel is dead straight,theres only a few reasons why there would be a difference from side to side.
Worst case-bent frame/k-member
Best case-one wheel has a different offset.
Or theres a spacer on one side.
Good morning everyone!
I have a 76 Dodge Dart. It came with 225/45/17 wheels & tires on the front & 235/55R17 on the rear. I have a problem with them rubbing on the fenders (front end). Can you tell me what the dimensions would be on the 14in wheels? Backspace/offset ?
So that I can start somewhere looking for a set of wheels and tires for my car?
Tia - Heather
Welcome to FABO and the coffee thread.... :welcome:
So, the honda dude still never talked to me.holding firm on price.
So my buddy didnt buy it.
And dude is showing car in my yard. I dont take kindly to strangers wandering around my property.
Kick it off
Should never be off by that much. Regardless what they did, they should have done same to both sides. I could see maybe half inch from frame, fender etc being off. The lower corner where it is actually rubbing can move a lot if the braces are missing or bent. Does it drive, steer, track OK? I'd be looking for accident damage if it's really off that much. A proper alignment would find any issues there.
Yes it drives and steers ok. Just rubs when you turn the wheel left or right because the tires are too wide or tall. I don’t believe it was ever in an accident either. I know it’s old and won’t ride smooth down the road like a car these days, so maybe my expectations are too high lol
Yeah but the tires shouldn't be offset that much. Do you have a picture by chance?
Hey Chris, did you see the one for Indiana?
Tune up on rincoln...
Didnt quite nail it. Didnt get one coul plug on properly. Back side under throttle body:BangHead:was making good time until that moment. a little silicone grease in connector would have been better before i put upper intake back on.
Got it done and no mis-fire.
Geo tracker,clutch pedal broke off the shaft. Pull seat, fight with welder and hope to not set anything good on fire. Just have to put seat back in. Tough welding down side up. No gloves no helmet and no room to escape if i drop a hot blob. :bs_flag:Job at best. Hope it doesent break.
