Stop in for a cup of coffee
Here it is.
That box next to it is a circuit breaker. Saw that in this thread. Send mike at AMS the picture bet he has one he is not the cheapest but he is reasonable. Arizona parts you really need a number for.
Might want to try to soak it in denatured alcohol and blow it out a few times see if the contacts clean up if you don't want to take it apart. Not much I can do without a part number.
Is that momentary up/down ?(have to hold it or it springs to center)
Good Morning
Have to hold it. Buddy thinks it has a small spring, same spring in the four way flasher. He said pull it apart and replace the spring. Hmm right and then if it falls apart I'm really screwed.
Also trying to confirm the two heater hoses for the 67 383 are both 5/8??
That's what I have and someone thought one should be 1/2 inch.
Don't think that change happened until 73??
Ordering a new heater core for it.
