It's another drive by for me, gotta go. Have a good day everyone.
I have some of that. I was hoping to find something to hold around 1200 degrees to be safe.Loctite 2620 is good to 650 degrees, don't know that that is high enough and don't know how well it performs so how's that for help?
?????Deacon has a line of high heat stuff we used to use on de-icing systems.
DEACON | Thread Sealants
Torque them properly and they shouldn't come out. Does it use a gasket? If the gasket is 'soft' or deteriorated then the threads lose tension.i know it's early but does anyone know of a thread sealant that is high temp enough to survive on exhaust manifolds?
If the thread hole is close to the water jacket, the iron will be closer to 210*F than the 1200 + of the exhaust gases.I have some of that. I was hoping to find something to hold around 1200 degrees to be safe.
I hadn't seen your post. Thanks Hoppy, that stuff will work. Trying to find it locally?????
It does. A metal one. Gonna replace it.Torque them properly and they shouldn't come out. Does it use a gasket? If the gasket is 'soft' or deteriorated then the threads lose tension.
Showed you what AMC did. Chrysler obviously didn't find it neccessary or they would have done the same or similar.
For $$ you should still be able to buy Spiralock made by Detroit Tool. Its a slightly better thread form, closer to Whitworth in cross section, designed for the purpose of preventing threads from backing out. I'd only do that if you continue to have problems.
Good luck always had to order it. Not sure if they will possibly give you a sample? Call them see if they will.I hadn't seen your post. Thanks Hoppy, that stuff will work. Trying to find it locally
All rise TMM is in the house. Ok you can be seated now!
For $250 it'd have to be for the car that has everything.Hey @ZMan67S
For the Cuda that has everything!
MOPAR NOS TAKE OFF PLYMOUTH DODGE RARE SPEAKER REVERBERATOR UNIT WITH HARNESS | eBay
Hope everything comes out ok for ya!
I always liked reverbs. Cool sound!For $250 it'd have to be for the car that has everything.
They sound cool as hell, I had one in my 1963 Grand prix, a great old car (one of my first I bought 15 years young) 389 flying hotel roomI always liked reverbs. Cool sound!
