All the way to each and every bearing
Yep, all in with additiveDid you pour it in the orifice properly?
Wow I can go on for days with that one!Yep, all in with additive
, I would to, and the inside of the floor pansHave to take the diff out of the cuda soon to do the bushings, just waiting to run the gas out of the tank so I can do it all at once the trunk pan, bushings and get rid of the undercoating. Think I will POR 15 the underside instead of undercoating.
Slow actually doing distrib work first then if I feel like it I work on it. Every thing I am doing with it now is overhead and fucks with the Vertigo. Sucks getting old., I would to, and the inside of the floor pans
Yep. Sure is. That should get some people's panties in wad.***MOPAR BROADCAST SHEET*** Interesting!
I would buy one. If I don't find the one for the cuda but will be known as a repop.Yep. Sure is. That should get some people's panties in wad.
Rightly so. too
As long as there is money to be made in patina there have been people who will provide...
Absolutely! With a few well placed shots you can sell it as a Bullitt Barracuda.Hey I do have that parts Cuda, and it is PA!
The one they pulled out of my car wasn't my car. It was the same color, but for a FB.Only places I have not looked is the heater box which is coming out and under the seat upholstery. Not there then there is not one.
Only place I would think it is now is in a bank folder somewhereHave it out, not there. Kind of hard to believe that car does not have one. Ripped the headliner out also.
Thats the low milage one? Might want to put on whatever you find to keep it as original as you can. My 67 came with very little undercoating - wheelwells and not many other spots.Have to take the diff out of the cuda soon to do the bushings, just waiting to run the gas out of the tank so I can do it all at once the trunk pan, bushings and get rid of the undercoating. Think I will POR 15 the underside instead of undercoating.
i found my 74 charger's under the dash pad when i pulled the dash.Only places I have not looked is the heater box which is coming out and under the seat upholstery. Not there then there is not one.
