you may as well sell the car now because your ability to learn from your experiences is naught.
You say this because I didn't follow your advice to the nth degree?
Many (Not all) thought the thicker head gaskets wouldn't help my situation, yet it has done just that.
Regarding the ignition mods you suggested, I tried slowing the curve. Funny, the word
curve doesn't really factor in since a 14 degree amount of advance in a dead straight line hardly appears like a curve...
RRR tried and tried to get me to delay the full advance until 3500 or so. I explained that when I eased up the rpms, THEN floored the car at 3500 or higher the car still detonated. I wrote MULTIPLE times that I felt that if his suggestions made sense to me, at 3500 (When in theory, the full advance would be in under RRRs advice) the car should have not knocked. This may be one of those things where two people are saying things that the other doesn't fully understand.
Again, whether I delayed the advance by way of distr. mods OR waiting until 3500 to floor it, I personally cannot see where the difference lies. There is no reason to insult anyone here either. If anyone cares to help me understand how or why I am wrong here, I'm willing to read. I'm not claiming to be the master of anything. I'm willing to admit where i am wrong.
These internet forums are voluntary. If someone reads my advice on something and decides to go another route, I don't continue to respond to the thread with..."Well, if you would have just done it MY way..." I figure that these threads are a guide to be used, not a recipe carved in stone.
Finally, I am not totally sold on a cam swap just yet. The Lunati was tried as a means to stop a detonation problem and it didn't work out. No biggie, that is life. Its not as if I raided the orphanage fund to buy these parts.
I am considering opening up the valve lash a bit to make the engine see "Less" cam. I might also advance the cam 4 degrees. These 2 moves may shift the power band a bit lower and soften up some of the bite. In reality, I shouldn't have wrote that the cam makes the car shake a bunch. It was an exaggeration. It shakes in comparison to what I'd prefer. No, I'm not looking for a totally smooth idle either. I just want something a bit more street friendly.
