1BadDodge71
FABO Rice Hater
Hello all,
Noticed something strange today with my 72 Duster.I noticed that when the engine is off and the key in the ACC position,when I turn on the lights,or even press the brake peddle or turn signals my radio will shut off and then come back on after I turn off either one.It never does it while the engine is running,only when not running in the ACC position.
I disconnected my stereo and hooked up my multimeter on DC volts and on acc,connected to the radio circuit,the meter drops from 12.65 volts to around 10 volts.I checked all the wires and non are broken or stripped.I'm wondering a voltage drop somewhere in the ground?Hmm.
I'll do some voltage drop tests.My battery is fairly new so I'm ruling that out.
I hate electrical problems :banghead::banghead:
