TartsHouseOfMuscle
New Member
How did the street demon work out ? I’m thinking about ordering one of the 625 cfm street demons for a mild built sbc 350I’m going to go with the Street Demon. Thanks everyone for your help
750 demon works well on my 340 , never a problem hot or coldHow did the street demon work out ? I’m thinking about ordering one of the 625 cfm street demons for a mild built sbc 350
Neither.get yourself a Holley 600 pretty basic carb. for your set-up..
Why run that junk on the street? Either run so much better and you can just forget about carb issues.
The street Demon seems like a good carb, pretty much a modern thermoquad. Know a few people that run them and they love them. Definitely get the resin bowl.I have a bone stock 5.9 Magnum I’m putting in a 87 Dakota. I need to get a carb. The tranny is a NV3500 stick. I plan on running either 3.55 gears or 3.90 gears. Stock Chrysler electronic ignition. Either headers or magnum manifolds for the exhaust. The intake is a Air Gap clone. What would be a good carb for this set up? I’m looking at either a Street Demon 625 or a Edelbrock AVS2 650. Also open to running something else but these 2 carbs should be plenty for my set up I think. I don’t have a carb so I have to buy one. Just wanting some opinions before I get one. Thanks
So we put one on my dad's 360 5yrs ago and we have never touched it.How did the street demon work out ? I’m thinking about ordering one of the 625 cfm street demons for a mild built sbc 350
I love my 750 on the 383.So we put one on my dad's 360 5yrs ago and we have never touched it.
750 WORKS great on my 340 3 years and counting started up no problem yestrdayI love my 750 on the 383.
Usually off idle stumble that hard to tune out is caused by Transfer Slots over exposed.The Carter/Edelbrock cam have an off idle lean stumble that can be very difficult to tune out. I know very well how to work on them and tune them (they're simple carbs). I've tried the avs and regular carbs and had the same thing. Anyhow other than that they're pretty good.
Coming back to this, I got my Ford 400 finally swapped in my truck and I stepped up 2 jet sizes and down two metering rod sizes and it's spot on so far. Runs just as good as with the 351. Better since I have a lot more motor.I have the Street Demon on my Ford truck and it runs fantastic. It's the 625.
IMO it's a damn good Thermoquad copy. Anybody that cannot see the resemblance needs to be selling pencils in a cup on the street corner.Yup, Ran a Street Demon 750 on a 410 w/Isky 280 Mega but on a 106 LSA (instead of the 108) Saw 14 in/hg in park, idled fine (yes, choppy, but consistent) and had a nice strong consistent chop with about 11 in/hg in gear. Stroker, dual plane intake, EQ Magnum heads with 1.92 intake valve, ports favoring velocity etc. Combo has an impact. Throttle response was outstanding. It’s a great street carb that can be run on the strip to a point. but it’s no Holley when it come to tune ability or ease as mentioned. I’d buy one again if I had a need, they’re nice and certainly not a cheap copy of a Thermoquad.
... I think Holleys get a bad rep cause ppl buy old ragged out used Holleys and not able to get them to run right.. .
If you haven't tried a Holley since the 70's your opinion is not valid of anything built in the last 10-15 years.I started with a new Holley in the 70's. I could tune it just fine. Tried everything and had it dialed in good enough for a "64" Barracuda with 273 to match the power to weight ratio of "68" 383 Road Runner. I just can't stand "having" to work on stuff, let alone fuel leaks, backfires, and burning your car to the ground. But when you get a really good, carb the Holley is nowhere close. No reason for me to ever run a Holley along with all the extra "tuning" parts. And for the record, I run original Carter carbs that are usually 50 to 60 years old with a 100,000 + miles on them. Just clean them up, put a kit in them, make your adjustments, forget about the carb, and enjoy your car. I get more power with better mpg with my used Carters than any Holley I tried.
