Most exhaust ports are too damn big. It's about senseless to try and develop an exhaust port on a flow bench because the tendency is to make it bigger so it flows more. That's just wrong.
Then you have heads with an exhaust port that is so worthless you essentially can't hurt it, like the SBM. You can hurt it, but not much. It's just bad. You put the best valve job on it you can, roll that edge called the short turn and run it because that's all there is. You may make the flow numbers go up with more work, but it won't make any more power.
Most of the small block based engines would be better off with a 1.550 or even a 1.500 exhaust valve if you can get a valve job on there. On my next set of W-2's I'm going to try my level best to get a 1.500 exhaust valve in there and literally clean up the short turn and the guide and walk away. I may have to go 1.550 so I don't need to use a 55* seat. But it damn sure won't be a 1.600 valve. That port is already on the big side and a bigger valve just makes it worse.
BTW, as an interesting note, when TF developed the new small block head, they actually FIXED the exhaust port and it is damn small but looks efficient. I'd love to flow test one. And it uses a 1.570 valve with a 45* seat. That makes me think I can squeeze a 1.500 in the W-2 with a 50* seat.
