unknownsnake Well-Known Member Joined Oct 18, 2009 Messages 1,866 Reaction score 50 Location Mason, MI Mar 25, 2011 #1 has anyone use the 440 source stroker kit? If so what one did you go with and how did you like it? How much work had to be done to block and heads other then the bore?
fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,265 Location Central, IL (Hooterville) Mar 25, 2011 #2 You might try posting this in the big block forum. This is the transmission/drivetrain forum so it may not be seen here by many big block guys.
