younggun86
Member
hello i have a 340 i was wondering where would be a ggod place to get a stroker kit from and if i can stroked it out more than 408 Thanks i jus wanna beat up on all of my buddies with gm or ford over here n atlanta,ga
There have been some good suggestions as to where to buy parts. I'd like to ad that the engine is only 1 little part to the equation. You can build a 600 HP monster but if you stick it in a 74 Duster (or any similar vehicle) leaving all other parts of the drivetrain and suspension stock you won't outrun much. Figure in your budget the trans. and suspension/tire mods needed.
BTW: here is the run down on the cubic inches gained with a 4" crank
Stock bore 340 with a 4" crank = 410 cubes
.030 over bore " " " " = 416
.040 " " " " " " = 418
Then if you have the money you can go with a 4.125" crank to gain approx. another 12 cubic inches.
Welome to FABO you'll like it here, Well I got mine from Indy cylinder heads, alot of the guys on here dont like them,(indy cylinder heads) guess I was lucky, I didn't have any trouble. if (I had to do it all over again I would get my stuff from a member on here ou812 Imm Engines he is a great guy and knows what he is doing he could get you everything you need) most here Like Scat products, I have all Eagle parts, guess it depends on how deep your pockets are, if your buddys have LS motors in thier GM's you will have to spend LOTS of cash to beat up on them as LS motors can be built for half of what a LA can be built for, JMO good luck. I still will NEVER own a GM. I do like some Phords though.
