Everything on the motor is MSDWhich type of spark plug wires are you running?
It was an error... I am crossing the line @ 6300.... is where the miss firing is starting127@6000?
Or is it 7200.
Or did you change it/swap rear gears? if not;
What's that convertor doing?
My compression is 10.5:1.... What is your suggestion?What is your compression ratio? Seems weird to runs 12 heat range plug and then mix C12 in there. If your compression is so low you can run a 12 you don’t need the C12.
Yep, will remove everything, including the electrical section...I agree with PRH, try removing the nitrous plate and see if the problem goes away. It is possible you introduced a vacuum leak with the plate, or maybe one of your solenoids is leaking.
Disconnect/disable the rev limiter. Loose timing chain &/or harmonics transmitted to the cam & then the dist can 'fool' the ign into thinking the rpm is higher than it actually is.
Here's a couple of wild guess's.........you are running out of gas, need more volume to the carb or valve springs are weak
Ok guys, thanks for all the feedback. Let me share some more details of how everything started...
Engine: Procomp heads with PAC SPRINGS ( Double springs with damper )
Solid cam .600 lift
Eagle forged crank, rods and pistons. ( Balanced )
Fuel system: Magnaflow pump, Pro systems 850 CFM carb
Ignition: MSD 6 AL Digital with MSD Blaster HVC 2 Coil, and MSD wires.
Champion RC12YC plugs.
I am running C12 mixed with pump gas.
Everything was running fine.
1 month ago, we installed a nitrous kit and a higher carb spacer....... ( the nitrous hasn't been activated or used )...... Here is where the problems started.
This weekend we tried:
Change from Champions spark plugs to NGK-7. We thought it was just fouled plugs.
Increase Carb jetting:
Front: from 76 to 80
Rear: from 86 to 88.
This helped a little bit....and struggling when almost away, but still there...
We changed the gap from 0.045 to 0.030, and the car felt on his nose passed 6000 rpm, It was literally like the car switched off...then came back to life......
We changed the gap from 0.030 to 0.045 and the misfire was there again, but didn't felt on his nose...
What brand distributor ???410 stroker, with Magnaflow fuel system, Pro systems 850CFM car, MSD Digital 6 plus ignition with billet distributor.....
The car is running clean up to 6000 rpm, after that the engine starts to struggle " kind of misfire".
We have changed fuel jets, spark plug gaps, changed plugs. But nothing seems to help.
Even when we close the gap from 0.045" to 0.030" it when worst. The car starts bugging completely down after 6000 rpm... I have the feeling it is somewhere in the ignition....
Any help will be appreciated
MSD Billet distributor........ MSD 8534 MSD Billet Chrysler Small Block DistributorWhat brand distributor ???
Could total timing be a playing a roll here?WHat is your fuel pressure at WOT?
What is the AFR at 6,000?
What is your top end limiter set to?
What ignition are you running?
WHat is the LSA?
What is the timing at 6k rpm?
Right now, we have it set to 34 degrees totalIt could. Too much WOT timing can limit top end, not to mention, it's undesirable anyhow.
From the looks of his broken procomp head in his newest post....I'd say yeah!
