[WANTED] Strut rod washers
cudamark
San Diego
Anyone have a couple of stock strut rod washers for a '66 A-body? Should be the same '63-6? I don't know if the newer ones are exactly the same or not, but they use the same part number through at least 1971. I'm doing a stock restoration with the original type bushings is why I want them, or, I'd just use the aftermarket washers that come in the aftermarket kit. They need to look exactly like this one. It measures 2 1/16" in diameter. The factory part number is 2071211. Thanks.
Just two will get the job done. One side of my car has the originals and other side has the aftermarket ones. Strange they would have just replaced one side! Let me know what you will want for them and how you want to be paid. Thanks.
I found 3 of them - 1 large 2 small of which the smaller seem to be the size you’re looking for complete with included surface rust.
