A little info..
..340 stroker (426) 10:00.1cr 32 degrees total advance @ 2800rpm. 904 Auto with 3500 stall.
-850cfm Pro-Form with #76 mains & #84 out back (#45 PV)
-Victor 340 intake with a 1 inch spacer.
When the mill is up to temprature 185 degrees, and Not under load, its has a stumble or hesitation ever so slightly. Also when at cruise, say around 3200rpm it seems to have a slight poping that can be heard through the mufflers. I belive it to be slighty to lean, the spark plugs are a very light rusty colour as well as the top of the pistons. Any thought on this would be great, looking for starting point to correct this problem.
