Subframe connectors, how did you do your cables and lines?
Ol'forest
Hamilton, New Zealand
Wanting to put weld in connectors on my 75 duster but thinking the park brake cables, brake lines and stuff will be a pain, can any one show me what you've done with your A-bodies?
I just did my sub-frame connectors this winter using a different approach that what i have seen done. i took a length of 1" x 2" x .100 wall tubing and spanned the length of the sub-frames starting at the point where it goes up for the wheel well at either end. Welded it under existing sub-frames allowed me to have 12"-14" of overlap to weld to . some work to clean the undersides of the sub-frames and a little notching to get it to fit properly. but overall very satisfied with the results. allows room for emerg brake lines and other misc. provides a conduit to run stuff from front to back. (left the ends open, just cut a 45 degree angle at both ends for aesthetics) sorry i don't have pics! the argument will always be that it would be stronger if ties to the floor but I am running a 45 year old floor that probably could contribute as much to the structure as the bond to the entire underside of the sub-frames. LIGHT ,CHEAP, AND EASY!
