Charlie Jourdain
Member
What are folks experiences with subframe connectors? I assume they are necessary for putting a 440 in a 67 barracuda. Probably the first modification I will make.
Necessary for putting a 440 in a Barracuda? Well, they came from the factory in '69 with 440 and no subframe connectors. Are they a good idea? You betWhat are folks experiences with subframe connectors? I assume they are necessary for putting a 440 in a 67 barracuda. Probably the first modification I will make.
I bet they had 4 torque boxes though. That was Ma Mopar's idea of chassis stiffening. Along with the double reinforced rockers on the convertibles.Necessary for putting a 440 in a Barracuda? Well, they came from the factory in '69 with 440 and no subframe connectors. Are they a good idea? You bet
yeah, they bragged how the unibody was structurally stronger than full frame cars.I bet they had 4 torque boxes though. That was Ma Mopar's idea of chassis stiffening. Along with the double reinforced rockers on the convertibles.
Charlie;
Mancini Racing is your best source for subframe conns.
The Cuda/Dart connectors are different than the Duster.
And Mancini is the only people who will tell you that.
Everybody else will sell you the Dusters.
Connectors are mostly used for race conditions. Just because you run a 440 doesn't necessarily mean you will need them. A hotly warmed over 440 used for Street & Strip: YES.
A stock 440: NOPE.
Some Racers who build 10 or more point roll cages say you do not need them. I disagree on that.
it's called a walker!Not necessary perhaps, but probably a wise addition. Especially considering the car is now over 50 years old. Hell I'd add subframe connectors to myself if I could. LOL
Great information, especially about making them longer than the "store bought" ones. Makes a ton more sense
