I am in the planning stages of building my final home on a parcel of land that I have had for 25 yrs. Where I would like to locate the new structure is approximatly 800 ft +/- from the existing well.
The well head works flawlessly for the existing structures ,mobile home/shop, which are located 150/300 ft distance from it.
I would like to utilize the well head if possible to keep the costs down.
Is it feasable to run a larger supply line such as a 2" line the distance then neck it down? Possibly replace the existing 40 gal tank with a pair of larger tanks? I'm just concerned with a drop in pressure.
The home will consist of two master bath suites and a kitchen with an additional water draw for a lawn irrigation system.
If you have been down this road or have working knowledge any input would be appreciated.
