I'm sorry for the Wall-O-Text. I want to start putting together a plan for the motor for my 68 Dart project. I currently have a 340/833 that I ran on the street from 88 to about 2001. It ran strong, but I have no idea of its history or specs. Then it was parked. I occasionally shot WD-40 in the cylinders and turned it over. Fast forward to 2016, It has not been run, but I have spun the oil pump and turned it over by hand. My intent is occasional track days, both Drag & Autocross, no single purpose, but an all around FUN car. My rebuild plan is: Machine work, a forged stroker kit, heads from somebody like IMM, Air Gap & FiTech EFI or similar & TTI Headers. I have a few questions- knowing that the 340 was the better factory piece, but today there are options.
1. I figure a roller cam is going to help a stroker be able to breathe better, by having more duration, yes/no?
2. Since I have the 340, & with the availability of roller cam kits for the 340, and that I plan on a crank & head change anyway-Should I build that or will I be ahead by finding a Magnum 5.9 to build?
3. There is someone near me with a 5.9 for sale with a spun bearing. Not worried about the bearing, but, would that be a sign of neglect that would say the motor might have other problems. Should I find something else, or should that not be much of a concern?
4. I like my 273 Shaft Mount Rockers. Am I correct that there is no way to use Indy LAX heads on a Magnum block (Magnum ports & chambers-but with LA valvetrain) because of oiling-no reasonable mods, correct? Is this not a concern because the Magnum rocker system is fine? -OR-
5. Do I need to figure on MAX heads & upgrade the valve train? At that point have I reached the balance point of having gone the roller cam in the LA 340 route instead?
I am not worried about originality, but I want a somewhat period correct look, so if I go Magnum, I will be using LA pulleys, valve covers, etc. Already have the headers though, so no hunting the elusive manifolds. I also know this hinges on whether the 340 cylinders can/need to be bored etc.
Any suggestions or insights are highly welcome. Thanks FABO for the previous help during the sheetmetal phase.
